Add component as reference in drawing
I've made a drawing of a cable (connector, cable and terminals).
Example :
cable_part.prt
cable_part_dwg1.prt
Now, for better explication of how to connect wires to the connector, I would like to add the connector component in cable drawing as reference and add some views of this connector.
It's possible ?
The other solution that I've found is copy a connector drawing view into the cable drawing.
This solution create a component connector as drawing reference.
With this solution I need to open the connector drawing and not only the component, again when I copy the view, if the connector view from is copied is outside the cable drawing format, NX give an error, then I need to change the drawing cable, past the view, move the view and change again the drawing format.
Apart my last solution, exist a more simple, fast solution to add different component views in other drawings ?
Example :
cable_part.prt
cable_part_dwg1.prt
It's possible ?
Thank you...
Using NX 8 and TC9.1
RE: Add component as reference in drawing
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry if I didn't thought before.
Sometime, solutions are under our eyes.
Thank you...
