Foundation design for blast loads
How do I handle blast loads for designing the foundation for a prefab building. The magnitudes of the load is way much larger than the conventional loading but the duration is in mili seconds. Does it mean the forces discipates before the foundation experiences them? Is there any guide lines to handle the blast loads for foundation design?
RE: Foundation design for blast loads
AISC Design Guide No. 26, Design of Blast Resistant Structures http://www.aisc.org/newsdetail.aspx?id=34548
UFC 3-340-02 http://www.wbdg.org/ccb/DOD/UFC/ufc_3_340_02_pdf.p...
Blast Resistant Structures, DESIGN MANUAL 2.08 from Naval Facilities Engineering Command
The short version is that stand-off distance is your friend and absent that it becomes a bit of a black art, as near as I can tell. My suggestion is that if you're the structural engineer stick to designing the building and (subtly) force the hand of the blast consultant; have him tell you what forces to design to. Conversely, if you're the blast consultant, advise the structural engineer as to what forces to design to and don't try to design the building components. But whichever your role, don't try to do both. That way there are clear delineations of responsibility.
That's my opinion only, based off of knowing that I don't understand blast forces.
Thanks for the links. But, I have to say, wow...
The Navfac one was close to 2,000 pages of mostly theory, though it did include some design examples. It seems like they provide various loading charts making reference to blast-specific terminology that I don't understand and then provide various material over-strength factors based on it's short-term loading, as near as I can figure. That's a lot to absorb and yet, at the end of the day someone has to issue drawings for construction that have to be build-able with the minimum number of change orders. So, to piggy-back off of a thread from yesterday it seems that we as engineers are expected to be able to understand and stuff like that and yet schools don't teach students fundamentals such as typical stud spacing. Are we losing sight of the forest for the trees?
I think maybe I'll resign myself to designing tool sheds, dog houses, out houses, and the like. Until people decide to start blowing up those structures too...
Foundations are typically designed for the peak reactions obtained from the superstructure dynamic analysis. These reactions are treated as static loads, disregarding any time phase relationship.................................
Thanks "delagina" . I will check with the blast consultant whether the foundaion loads are from dynamic analysis.
