problems in WWTP
problems in WWTP
I am having low oxigen levels in my aeration tanks and not being able to really understand why it's happening now. Can someone please give me a hint?
Thank you
Thank you
RE: problems in WWTP
might be it's because of diffusion of plug. However, you should try to check the complete part!
http://www.magicrubbishclearance.com/
Has your waste stream changed? Is someone dumping something in large quantities that could effect your aeration? Have you checked COD/BOD on influent to see if it is normal?
