scaling issue
scaling issue
I am a beginner here, please please help me.
I got a *.dxf file and opened,
But the problem is its dimension is different from original file.
So I'd like to scale it 1.39 times bigger, (on x,y coordinate)
How can I convert it?
ex) certain distance is originally 11.12 but in the dxf file, it comes out 8.
So I want to make the distance as 11.12 to multiply 1.39.
Thank you,
Thank you,
RE: scaling issue
click or type scale/
click any point/
type in the factor you want=1.39###
RE: scaling issue
type on the command line:
scale
all
[enter]
pick one end of the object that is 11.12xx long or the first point that is 11.12xxx from the other
R
pick the other end of the object that is 11.12xx long or the second point that is 11.12xxx from the first point
8.00
[enter]
RE: scaling issue
