Strange behaviour between workstations
I've different NX behaviour creating views.
One workstation each mouse movement, NX goes in updating, others workstation work fine.
I've deleted all file under the profile.
Which Windows registry setting I can delete so when NX restart, recreate in clean resgistry setting ?
Thank you...
Using NX 8 and TC9.1
RE: Strange behaviour between workstations
NOTE ( for all readers except Cubalibre) : Stay away from the registry if you do not know what you are doing !
What i do when weird things like this happens is to rename the key :
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\8.0
into for example
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\original_8.0
( note that this MUST be done when NX isn't running! )
Then when you start NX you will get a new NX8.0 key in the registry.
and if i am happy with the new i can delete the copy, or go back to the original one.
Tomas
I will try to reset this settings, hoping that will resolve this big problem.
Thank you...
