Design Factor for Pipeline Anchor Flange
What design factor should be used for a pipeline anchor flange?
RE: Design Factor for Pipeline Anchor Flange
A. If there is not a big cost difference then use the worst case.
B. If there is a big cost difference, then present your figures to your Client and see if they want to be realistic (cheaper) or conservative (more expensive).
prognosis: Lead or Lag
In such case, I don't know if any design factor would need to apply.
You should use the design factor specified by your design code, 0.72 if it is B31.4, or that specified by your class location, if it is B31.8, probably 0.60, 0.50, or maybe 0.40 if it's in a large city location.
I hate Windowz 8!!!!
ASME B31.4 Table 403.3.1-1 Allowable stresses allows 0.90 * Sy for additive longitudinal stress SLand for sustained and occasional loads.
