Ordinate dimension
Ordinate dimension
Hello
i have created an ordinate dimension. but later i found out that i dont need it and i want to delete the start points (i mean the yellow arrows that are created on the begining ) it was been told me that the yellow arrows that are created cant be delleted... is it truth?
RE: Ordinate dimension
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
so i uploaded the image of my problem. im using nx7.5 and the problem is how can i delete a ordinate dimension (the axis they are created as a startpoint for this dimension). i know they are showinng up only when i`m working with it, but annyway...
http://files.engineering.com/getfile.aspx?folder=3...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for answer but i dont think i fully understand the start of the sentense : "OK, with the Ordinate Dimension 'dialog/toolbar' open "
but i have found the setting for ordinate dimension .... the problem is i dont understand how to change the specify ordinate dimension ...
thats what i have done :
i just clicked on the icon of ordinate dimension and in the menu bar that showed up i clicked on the "A" blue button allias settings and then i have done other steps... but nothing happend. :)
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If I accidentally create more origins, how can I delete the unwanted ones?
If I want to use User-defined stile ordinates, how can I define the positive directions?
Thanks in advance.
kukelyk
radohric after clicking ordinate dimension command your ordinate cordinates are heighlighted as you show in your image of yellow arrow,
after that just select axis of one of your co-ordinate which you want to delete then go to setting where you see Display name style in that you have select ordinate set name...so after that you see ordinate on drawing so you can delete it
Nitin
Nx -7.5
Teamcenter-8.0
iHungry Always
