How do I keep an Indentification symbol used in a note from being associated- read below please
My question is: I used Identification symbol “delta” with a number in it to put next to a note in a drawing.
As I bring the delta up to the note the delta becomes controlled by the note meaning the note moves away from the delta and the delta ends up at the top of the note and then I move it where I want it to be placed and again they act like opposite magnets.
How do I get the note and delta to not be associated to each other, is this a hinge line thing and if it is how do I COMPLETEY shut off hinge lines.
Thank you!
RE: How do I keep an Indentification symbol used in a note from being associated- read below please
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
And once you select one of these 'Alignment' options, dialog memory will remember that setting the next time you go to create another annotation object of that particular type. That is, you can have notes being created with an 'Associative' origin while symbols are set to 'Non-associative'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
<C1.1><Y1.5>$8<Y><C>
The <C1.1> increases the character size of the delta symbol by a factor of 1.1 as compared to the rest of the text, so you can change the "1.1" to something else if you want.
You may also want to tweak the <Y1.5> to a number other than "1.5". This is the aspect ratio of the triangle. If you change that number to simply "1" you will see what the default shape of the triangle is.
