Submitting thousands of jobs
Hello!
I'm trying to implement a new optimization routine in Abaqus, and for this I'd need to submit thousands of jobs in as short a time as possible.
As a starter, is it possible to do something like this:
1) Start with a simple 2D structure (call it A)
2) Remove a fixed number of random mesh elements
3) Get max Mises on result
4) Repeat a few thousand times, each time starting from A
I've got a script that can do steps 1-3. Can I do this 1000s of times efficiently? Maybe with substructures?
A prod in the right direction would be really appreciated!
RE: Submitting thousands of jobs
It's probably better to make your structure based on some parameters, and change those, instead of deleting random elements.
What some programs do is removing low stress areas, and adding to high stress areas, iteratively.
What you're describing is Evolutionary Structural Optimization. I'm hoping to get better results using an approach based on Monte Carlo algorithms, hence the rather weird steps (which are a big oversimplification of what I'm trying to do).
I've found very little usable information about substructures (the official documentation doesn't seem to cover what I want). Essentially the models I which to test my approach on (as a proof of concept) are extremely simple. Imagine a 2D rectangle split up into a mesh. I remove an element, analyze the result, and use max Mises to give a 'rating' to the resulting structure. Since this is Monte Carlo, I need to do this kind of step as many times as possible. Yet Abaqus takes a lot of time submitting the job, pre-processing, saving the results in a file etc. which it evidently isn't doing when you choose the default structural optimization job. Is there any way I can have that kind of speed? Otherwise my whole project is unfeasible...
TTFN
Over the last two weeks I've been increasingly impressed by Abaqus, but it seems to me it's not suited for what I want to do...
Does anybody know of something I'm missing? And if not, do you know of any other program that would be quicker?
"mdb.JobFromInputFile(...)
mdb.jobs[name].submit()"
causes pre.exe to be run? I thought pre.exe just made the input file for the next stage? Since this is the step that's taking the longest, removing it completely would be great.
I am also a new ABAQUS user and am curious why the pre.exe takes so long. I think it is because the input file can contain commands like "*NFILL" so the nodes are not defined in the input file and need to be generated by the pre.exe executable. I would be very interested if this step could be removed when a job is submitted.
I do not think that there is a quicker method if you want to still use abaqus.
if you find one, please post it to the forum.
