API 661 Shoulder Plugs and Gasket
Hello.
Any of you have some information about API 661 Shoulder Plugs and Gasket (drawings, dimensions, etc). I can´t find these in my country as standard fitting. I need to built it from zero.
Thnask in advance
Fernando - Argentina
RE: API 661 Shoulder Plugs and Gasket
The shoulder plugs have to be manufactured in accordance with API 661 (I assume you have acopy of it) and the supplier of the air cooler is the supplier for the plugs and gaskets. Don't try to get involved in the manufacture of those plugs, unless you are very familiar with the design and manufacture of them. You get them supplied with your cooler and you can always go back to the manufacturer for spares. They will come with suitable guarantees from the manufacturer.
Cheers,
gr2vessels
