Removing edge blends with lost references
When creating complicated castings, we often get the lots of edge blends where the edges have been consumed by another feature or similar and our part navigator ends up with lots of warning triangles on those specific blends. Other than editing each edge blend separately and clicking the delete button inside the command, is there a way of deletin these enmasse? Using a journal perhpas? I thought part clean up might do it, but it doesn't.
Cheers
Si
Best regards
Simon NX 7.5.4.4 MP8 and NX 8.5 (native) - TC 8 www.jcb.com
RE: Removing edge blends with lost references
Hi JCBCAD,
i was just wondering if you can use CheckMate (Buried Features check)results (Visual Reporting) to filter all these blends and then delete it in one shot (right click the top-node of the reult and selecting SELECT ASSOCIATED OBJECTS and delete it).
Or maybe using FILTER SETTINGS in part navigator to filter down features " features with warning" and then delete them.
Best Regards
Kapil Sharma
JBCAD Did you ever find a good solution to this question? Thanks
SDETERS
Nothing other that what you see here.
Happy New Year smile
Best regards
Using selection intent (tangent curves, connected curves, face edges etc) instead of selecting multiple edges would minimise the number of consumed edges, although the feature would fail if the seed edge is consumed upon editing.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
It's fixed in NX9, it basically deletes any lost edges for you smile
Best regards
Thanks gives us another reason to push for upgrading to NX 9 in spring time.
Hi Simon,
I'm testing NX9 and I don't find this fix.
Is it an information arrived from SIEMENS or have you tested personally ?
Thank you...
Using NX 8 and TC9.1
Here's some code, but it is not thoroughly tested. Post back if/when you encounter a problem.
CODE
'http://www.eng-tips.com/viewthread.cfm?qid=356772
'clean invalid edge references from edge blends
'not thouroughly tested for variable radius blends
'February 10, 2014
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module BlendCleaner
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoName As String = "Blend Cleaner"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, undoName)
        Dim numCleaned As Integer = 0
        Dim nullFeature As Features.Feature = Nothing
        Dim currentFeat As Features.Feature = workPart.CurrentFeature
        Dim prevFeat As Features.Feature = Nothing
        For Each tempFeat As Features.Feature In workPart.Features
            If tempFeat.FeatureType = "BLEND" Then
                Dim myBlend As Features.EdgeBlend = tempFeat
                Dim blendWarnings() As String = myBlend.GetFeatureWarningMessages()
                Dim needsCleaning As Boolean = False
                For Each myLine As String In blendWarnings
                    If myLine.ToLower.Contains("consumed") Then
                        needsCleaning = True
                    End If
                Next
				'make previous feature the current feature
                prevFeat.MakeCurrentFeature()
				'edit blend feature with rollback
                workPart.Features.SetEditWithRollbackFeature(myBlend)
                Dim blendBuilder As Features.EdgeBlendBuilder = workPart.Features.CreateEdgeBlendBuilder(myBlend)
                Dim validEdges As New List(Of Edge)
                Dim myCollector As ScCollector
                Dim myExp As Expression
                Dim valid As Boolean
                For i As Integer = 0 To blendBuilder.GetNumberOfValidChainsets - 1
                    blendBuilder.GetChainsetAndStatus(i, myCollector, myExp, valid)
                    Dim myObjects() As TaggedObject = myCollector.GetObjects
                    For Each temp As Edge In myObjects
                        Try
                            temp.GetLength()
                            validEdges.Add(temp)
                        Catch ex As NXException
						'edge has been consumed or suppressed
                        End Try
                    Next
                    Dim edgeMultipleSeedTangentRule1 As EdgeMultipleSeedTangentRule
                    edgeMultipleSeedTangentRule1 = workPart.ScRuleFactory.CreateRuleEdgeMultipleSeedTangent(validEdges.ToArray, 0.5, True)
                    Dim rules1(0) As SelectionIntentRule
                    rules1(0) = edgeMultipleSeedTangentRule1
                    myCollector.ReplaceRules(rules1, False)
                    Dim csIndex1 As Integer
                    csIndex1 = blendBuilder.AddChainset(myCollector, myExp.Value.ToString)
                Next
                blendBuilder.CommitFeature()
                blendBuilder.Destroy()
                numCleaned += 1
                currentFeat.MakeCurrentFeature()
                workPart.Features.SetEditWithRollbackFeature(nullFeature)
            End If
            prevFeat = tempFeat
        Next
        If numCleaned > 0 Then
            theSession.SetUndoMarkVisibility(markId1, undoName, Session.MarkVisibility.Visible)
        End If
        lw.Close()
    End Sub
End Module
www.nxjournaling.com
I get this error Cowski.
Line 49 "SetEditwithrollbackfeature" is not a member of "NXopen.Features.FeatureCollection".
LINE 91 "SetEditwithrollbackfeature" is not a member of "NXopen.Features.FeatureCollection".
I should have mentioned that I tested it on NX 8.5. "SetEditWithRollbackFeature" is new to NX 8, I'll see if there is an alternative to use in NX 7.5...
I am on nx7.5 Sorry
Ok, this version tested with NX 7.5.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module BlendCleaner_75
    Sub Main()
        lw.Open()
                    End If
                Next
                If needsCleaning Then
                   'workPart.Features.SetEditWithRollbackFeature(myBlend)
                            Try
                                temp.GetLength()
                               'lw.WriteLine("  error: " & ex.Message)
                            End Try
                        Next
                    Next
                    numCleaned += 1
                    'workPart.Features.SetEditWithRollbackFeature(nullFeature)
                End If
            End If
            prevFeat = tempFeat
        Next
        End If
        lw.Close()
    End Sub
End Module
This works great. Slow to rebuild the model but it could be an issue with my model. Nice One hundered stars to Coswki.
It looks for blends with missing references, if these occur early in the file it will essentially rebuild the entire solid. On large files, this can be a long process.
