Pipeline Welding Techniques
Good morning,
I am working with piping company which specialized on only aboveground pipeworks. And there is an upcoming pipeline work that we will possible get awarded.
Our old procedures are outdated, could anyone explain me current pipeline works. I mean is 2-3 group stick SMAW welding still popular?
Should we do Argon GTAW root and then SMAW fill? Work is roughly 100km, will full SMAW be faster? Or is it not worth it due to the better root result with GTAW root.
RE: Pipeline Welding Techniques
In my humble opinion, you should start by reading this textbook for beginners: http://www.kobelco.co.jp/english/welding/events/fi...
By the way, in your company, what part of the work are you involved with?
El que no puede andar, se sienta.
Other than good penetration is there other pluses to use 6010?
Best regards - Al
It's true that GTAW gives good root but if you prefer higher productivity you can switch to GMAW-STT that is a type of GMAW process with which root can be effectively welded. Please have a look at this link: GMAW-STT (Surface Tension Transfer) for CS
regards,
wegm
SFA-5.20 Part C states the following: The "G" indicates that the external shielding, polarity and impact properties are not specified.
Best regards - Al
