Easiest way to replace components in Pro E
I need to replace a component in an assembly that has a large number of parts attached to it..(75!! ARRGH)
This is the process im following currently.
Disable the constraints on the Component in the definition.
Insert the new component in place.
Hide the old component and replace all dependencies on it with the new one.
This is quite the simplest method i know about, but its really repetitive although its easier than Right click -> Replace component -> by Layout (i loose all my references in this method).
Is there a better method than this?
Im using PTC Wildfire 5.0
RE: Easiest way to replace components in Pro E
