Model to drafting unwanted lines showing up
Hello, after modelling a part and then going on to draft it, I noticed that some lines behind surfaces were showing up for some reason. Also, at the edges where I chamfered them, you can still see the original edge as well as the new. Any help would be much appreciated. Thank you.
RE: Model to drafting unwanted lines showing up
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It would be nice to have some images of your model but as you mentioned "SURFACES" it could be a result of multiple copies of sheets (may be you have hidden them but are in the same layer and hence appear in the drafting view).
Best Regards
Kapil
Have the views been updated?
Are there any sketches and/or any other geometry that shouldn't be in the reference set?
www.nxjournaling.com
