NX9 Save as
NX9 Save as
When doing a save as of a component in an assembly UG asks you to do a save as on all the open files that have that component, it would come up in the information bar telling you what file you are doing the save as to now. It still asks you but does not tell you what file you are renaming.
Any Ideas?
Any Ideas?
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.0.19(testing)
If you can think it it can be modeled
RE: NX9 Save as
You should log an incident report (IR) with GTAC so that they can fix it properly in the next maintenance release.
www.nxjournaling.com
RE: NX9 Save as
Ryan Lee
NX 6.0.5.3
RE: NX9 Save as
Log a new PR and quote that PR as an existing one to be added to.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3.4
NX8.5.0.23 -> NX8.5.2.3 & NX9.0.0.19
RE: NX9 Save as
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
RE: NX9 Save as
RE: NX9 Save as
Until then, the workaround I've been using is to look at the information window, as it will update as you work through each filename. Not ideal, but it's a workaround.
Anthony Galante
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.1
RE: NX9 Save as
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: NX9 Save as
Ryan Lee
NX 6.0.5.3
NX 9.0.1.3(Testing)
RE: NX9 Save as
Anthony Galante
RE: NX9 Save as
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
