US Equivalent to EN 10210-S355 J2H grade Seamless Tube
Hope someone can help me with this query. I need to find a en equivalent US grade to EN 10210-S355 J2H (1.0576), which is a structural non alloy steel good for relatively cold temperatures. I need seamless tubes not pipes. It is the low temperature application and sizes what is making it challenging to find. A333 grade 6 or API 5L X52 PSL 2 are good alternatives, unfortunately they don't come in the sizes I require. Any help will be highly appreciate it! Thanks
RE: US Equivalent to EN 10210-S355 J2H grade Seamless Tube
There will be some machining involved, so the final sizes of the tubes needed are:
OD(in) ID (in)
2.45 1.50
3.6 2.26
4.50 3.0
6.75 4.8
8.75 6.9
Anything slightly thicker/bigger will help.
I look at API 5L X52 PSL 2 , and if you look at the measurements shown here , this is good .
but if you look at ASME B36.10M 2010 then gives these other sizes .
