Could not open - Modeler error: value is not as expected
I've been working on a part for weeks without any problems and suddenly I'm unable to open it, getting this error:
In the log I see:
PK function PK_ATTRIB_set_doubles failed, ifail PK_ERROR_bad_value (39), severity Mild
*** EXCEPTION: Error code 820039 in line 1844 of o:\ugnx90\ip19\src\dman\no\ind\ki_errors.c
+++ PK ifail 39 from PK_ATTRIB_set_doubles
Ug_inspect-scan says "Found no known corruptions". Does "value is not as expected" tell me anything or have I lost the part completely?
Using NX9 on win7 64.
RE: Could not open - Modeler error: value is not as expected
Contact GTAC, they may be able to help.
www.nxjournaling.com
Hi ,
There are chances that this may be a corrupt file (however as Cowski said GTAC needs to look into it.They only can tell what the real issue is).
But have you tried opening it up on some other system also? Were you accessing this part file from some remote location through network? I am not sure but it looks like you are working on Native NX only (no TC?).
Thanks and Best Regards
Kapil Sharma
Reboot your computer.
Copy the file to a local disk.
Run ug_inspect on the file.
If it does open, run Part Cleanup.
Call GTAC.
Ben Loosli
I am accessing the part from the local disk without teamcenter. Like I said, ug_inspect shows no problems.
I've worked out what triggers the problem, and it is reproducible. If I create an extract geometry -> body of a few complex sheet bodies inside the part, then save the part, close and then try to open, the error occurs.
Hi xdc256,
Although you have yourself figured out the reason behind it but you can try running an examine geometry check on the sheets causing issues while extracting.
Best Regards
Kapil
Examine geometry shows no issues. There is no problem when extracting, the issue is that subsequently saving the part corrupts the file. While I've now seen it happen on multiple different sheet bodies, for one of them there was a single clean surface produced from a face blend that somehow produced the error.
Since you can reproduce this problem on demand, then you should DEFINITELY contact GTAC and have them open an IR/PR!
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Try the Export - heal geometry since it seems connected to the geometry, - And sent the part to Gtac, things like this should not happen.
Tomas
