Effects of cold weather on concrete compression strength test results
Civil Folks,
I have run into a re-occuring problem of concrete samples not meeting the required 32MPA strength and was wondering what kind of effect collecting the samples for testing in cold weather (-20 - -35C) can have on the test results. Any input is appreciated.
Ron
Ron
RE: Effects of cold weather on concrete compression strength test results
Dik
As for the laboratory, if the curing temperature dips (even slightly), strength results are affected adversely.
Dik
As to mortar, I used the rule that no freezing should be allowed in the first 24 hours to be acceptable work.
