suspension lifts on small trucks
Ok guys try this again.
what is the caveats of suspension lifts on small trucks with aftermarket torsion bar keys.
what type of stress or distortion on the front ends. I know jack about nothing.
RE: suspension lifts on small trucks
Mike Halloran
Pembroke Pines, FL, USA
it seems this particular truck is not very well supported.
The mention of torsion bars implies that whatever the vehicle is, most likely uses a double-A-arm front suspension of some sort.
Small changes in ride height will likely remain within the bounds of maintaining acceptable suspension geometry and constant-velocity joint angles. But small changes in ride height probably won't do much to address the ground clearance issue that you seem to have.
Large changes in ride height will require some sort of re-engineering of the suspension, steering, and drive line. I've seen subframes built that essentially move all of the suspension attachment points and the front diff down relative to the frame and change the angle or position of the diff to minimize the bad side-effects on the front drive shafts. There will be an unavoidable rise in the center of gravity of the vehicle (it'll be more prone to roll-over).
If it is a road vehicle, raising it up will raise the height of the bumpers (lethal to other vehicles in a collision - and don't forget that raised center of gravity that makes it more lethal to you, too), the height of the headlights (you'll be "that guy" blinding others at night), etc., and in some areas (including mine) it may make the vehicle uninsurable or illegal for road use. Of course, if this is an off-road vehicle, none of this matters.
My original post before this one had all the information.
but for some reason eighter by complaint or I some how broke the rules.
it was therefore deleted.
this a ford ranger 2011. 4x4 looking at 3 " lift.
Given that this is a rather common vehicle that has been around for decades, it's pretty likely that what's out there on the market is reflective of what you can and cannot get away with.
all what you say above is true. but hence why I am here to get the dope regardless of good or bad.
I looking at 3" max lift + taller tires. The lights are an easy adjustment. The bumper are pieces of crap.
I have been looking at aftermarket bumpers. I have 75 acres of desert with lots of rocks. hence thats why I need the lift.
it may be cheaper to buy street legal off road bikes.
