NX Post builder
NX Post builder
I would like to stop the posting if I have a serious problem.
Can I do a command during posting of an NX file to stop the posting?
If I use the exit command, it not only stops posting, but it also exits NX as well.
I am hoping there is an other option.
if { $set_error == "99" } {
MOM_output_literal "( - check tool diameter ERROR Code $set_error - )"
exit
thanks
Lvee
exit
thanks
Lvee
RE: NX Post builder
MOM_abort "\n\n*** check tool diameter ERROR Code $set_error ***\n\n"
the \n gives a blank space between the NX error output and your message and makes it clearer for the user
RE: NX Post builder
This would work.
MOM_abort_event I think would also work.
Is there an advantage to using one over the other?
Lvee
RE: NX Post builder
I don't beleive that MOM_abort_event would satisfy your requirement.
As I understand it MOM_abort_event can be used to abort processing of a procedure (same as the 'return' command) or of an event (like linear move, rapid move etc). This will not abort post processing as far as I am aware.
MOM_abort will abort post-processing and also allows you to enter a message as to why.
danruk
RE: NX Post builder
It is very helpful to the end user if you add an error message that makes sense.
I will include the $mom_operation_name in the message
For example
if { $mom_update_work_offset_defined == 1 && $mom_ba_dynam_offset_xy_defined == 1 } { MOM_abort "
HEY!! you cannot change both dynamic and standard work offsets FIX the $mom_operation_name operation
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
