Frame with braces
Frame with braces
Hi everybody,
I've got a problem. I've got a steel structure - frames and vertical and roof braces. When I try to assign the loads on it using area uniform to shell function in the fields, where are the braces situated, they receive loads. I've read how to prevent this, but I compare two models with same geometry - the first one with moved braces and the second one - without moved braces. They have completely different modal behaviour. Do you have any idea why is this so?
RE: Frame with braces
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
