Fill annular area with equispaced holes
I wish to fill an annular area with a pattern of equispaced holes. Image gives an idea of what I want using a pattern along roughly spiral curve. Number of holes is fixed.
Is ther an easy way without going into complicated mthematics?
Many thanks
RE: Fill annular area with equispaced holes
pattern on a curve
You will need to use a Curve by Table to generate the path curve.
Can I ask why you need a curve of that shape?
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
The design intention is to have holes evenly distrubuted in 2 dimensions . I am using part to fixture a fixed number rods so that maximum spacing between rods is achieved in a circular arrangement.
I was hoping there may be a simple fill command similar to pattern pattern.
I eventually went with patterning along a distorted helical curve. Worked out OK.
thanks
