Linke refused.................
5
I'd like to replace the link of this drawing (linked to part1).
I'll add the new part (part2) that I'd like to replace with(in the next attachement.
MZ7DYJ
RE: Linke refused.................
If the Part your replacing does not have the same UUID as the original Part in the link, it will be refused. In Drafting, go to Edit > Links. Thats where you can change links.
I used In Drafting, Edit > Links, but it doesn;t work!
How could I change the UUID?
MZ7DYJ
you don't.
only way to change the link is with scripts but dimesions will lose links... search forums for more info
Eric N.
Thanks a lot!
MZ7DYJ
3
@mz7dyj
You can't change the drawing view links manually via Edit > Links, but you can do it with a vba script as itsmyjob recommended. See code below and attached images.
CODE --> vba
Sub CATMain()
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.ActiveSheet
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.ActiveView
Dim viewLinks1 As DrawingViewGenerativeLinks
Set viewLinks1 = drawingView1.GenerativeLinks
viewLinks1.RemoveAllLinks
Dim partDocument1 As Document
Set partDocument1 = CATIA.Documents.Item("square.CATPart")
Dim viewBehavior As DrawingViewGenerativeBehavior
Set viewBehavior = drawingView1.GenerativeBehavior
viewBehavior.Document = partDocument1
viewBehavior.Update
End Sub
Drew Mumaw
http://www.drewmumaw.com/
http://www.textsketcher.com/
Thanks!
MZ7DYJ
It's pretty sad, yeah. I know one company who wants every .CATPart stored underneath a .CATProduct, and then the drawings get made with links to the .CATProduct. This way the system does not complain about "refusing the document" with the same UUID .CATProduct being re-used and the .CATParts get unique UUID assignments.
It's an awful workaround, and I wouldn't recommend it.
Does that macro work as well as it sounds?
relinking with macro does not relink annotations or dimensions... all links between drawing element and projected 3D will be lost (according to my testing way back then)
Eric N.
Thanks, itsmyjob & drewmumaw, was really searching for this type of solution to edit the link of a cat drawing.
Till now i was also getting the message of link refused, but now it is solved.
Just one more question ,will it work for complicated & bulky cat products & cat parts ?
Himanshu
@hims1980
I don't know. You'll have to test it. To be honest, I don't use it too much. If CATIA doesn't allow you to relink drawing views manually because of the "Link refused" error message then it makes me apprehensive to do it programmatically. I only use it out of necessity. It might retain ghost links, cause other problems behind the scenes, etc. I would use KevinDeSmet's suggestion of nesting components inside a shell CATProduct so that the drawing is always linked to that CATProduct. Then your subparts and subproducts can be swapped without encountering the "Link refused" error message. My two cents...
Drew Mumaw
@KevinDeSmet, but how could one store all the cat parts underneath a catproduct, because when you will check the links of a cat drawing having assembly views taken from a cat product, then in the "EDIT-LINKS" CATIA shows all the linked catp products as well as cat parts.
And how about the cat drawing to be created from a cat part & not from cat product ?
Please correct me if i have misunderstood.
Himanshu
Yeah you're right. As I said I only read that workflow, ain't never done it myself! I guess then they were unique .CATProduct files but they each had the same UUID which allowed the links to be re-linked. I guess?
Ultimately, this must be some kind of brainfreeze in CATIA because I don't think very many other MCAD systems have this problem...
