Creating Rigid Bearing Plate
I am modelling a simply supported reinforced concrete beam. The beam is supported on steel bearing plates. I want to model the bearing plates as rigid bodies. I want the plates to be able to rotate, have lateral displacements and be rigid. Can someone help me determine how I should be assigning the Reference Node, Body Elements, Pin Nodes or Tie Nodes required for a Rigid Body constraint?
UWStructEng
