Stacking Text
Stacking Text
In ACAD, I was able to stack text so that it would look like a stacked dimension. However in DraftSight I don't seem to be able to do this. For example, Drill 7/32" Dia. Holes - Typ. 4 places. I want the 7/32 to be horizontally stacked. Does anyone know of a workaround for this seemingly minor problem?
Thanks! :)
Thanks! :)
RE: Stacking Text
To set text as a fraction, enter following text in properties window: 3{\S1/2;} or 3{\S1#2;}
Breakdown:
3 ___ is the regular text
{ ___ isolates the following command
\ ___ starts the command
S ___ is the command to stack
1 ___ is the numerator
/ or # ___ is the operator
2 ___ is the denominator
; ___ ends the command
} ___ ends the isolation
\P ___ executes a carriage return
RE: Stacking Text
