Dedicated Outdoor Air System vs. Recirculating System
Im in a debate over indoor humidity levels. I believe a recirculating air system bringing in a percentage of outdoor ventilation air will have higher humidity levels compared to a 100% outdoor air system. The building is a high school in a remote location, very cold dry northern climate. Mechanical humidification is not an option so I believe using a recirculating system will help keep the moisture added from the occupants within the building. Any input is very much appreciated. Thanks.
RE: Dedicated Outdoor Air System vs. Recirculating System
If you think you need humidification (outside a museum or similar application) your building and/or premises are faulty.
edited by Heinz R. Trechsel - Chapter 8.
With that tidbit of information you can plot your process on a pyschrometric chart and let us know the outcome.
