Effect of multiple annealing+aging cycles on room temp mechanical properties of 17-4 PH
Hello everyone,
I wonder if anyone could point me to articles or studies that determined the effect of multiple annealing+aging cycles on the properties of martensitic PH stainless steel such as 17-4 PH or 13-8 Mo.
Best Regards,
Best Regards,
RE: Effect of multiple annealing+aging cycles on room temp mechanical properties of 17-4 PH
In general the properties of these alloys improve withe repeated anneal+age cycles.
There is some grain refinement that happens each time.
I know that impact toughness will improve.
Yield strength may go down slightly, buy UTS will stay the same and elongations will increase.
Plymouth Tube
A lot would depend on the cooling from solution treatment temperature, as well as the number of cycles. If you are talking of hundreds of solution treatment cycles using a oil quench, for example, things are going to change quite a bit between the first couple of cycles and the last ones. Your round bar you started with may not be round any more, so it's bending strength may change, even though the yield stress is remaining the same.
rp
EdStainless, would you please shed some light on the grain refinement with more cycles? I thought it would cause prior austenite grain growth.
Thank you,
As long as you don't over do the time and temp for the anneals then you will get grain refinement.
I have had projects where welds were required to meet difficult impact toughness requirements.
A cycled heat treat allowed us to get the desired results.
Plymouth Tube
A secondary reason is due to quality non-conformance issues. Every once in a while there was a cycle where temperature overshot by a few degrees for a few minutes. In my environment, it is extremely unlikely that such cases can be accepted without further processing. Generally they were scrapped.
