simple output objekt example for nodal translation in VBA
Hello dear community!
I am just learning how to use the femap API language. At the moment I am a bit confused while dealing with the out put object, although I have read the examples and guidelines at the FEMAP help and some stuff using google. Either the topic is focused not on output objects or it is quite cumbersome for a beginner like me.
So I just wrote an example Code and made it run in Excel while I had an open project in Femap (1 plate Element with 4 Nodes+ displacement and stress results) which is unfortunatels wrong.
Maybe somebody has a very simple generel VBA script for this kind of problem. So a skript which just read and puts the displacement results of 4 Element Nodes of one Element out in Excel, for example? That would be great!!!
Best regards
Hans Peter
Best regards
Hans Peter
