Different solid (look) in "Explosion" and "No Explosion"...
Hello
I've made 'Replace Component' and everything is well in 'Modeling' (correct name/number and solid)... but in 'Modeling-Specification' i've wrong 'Explosion View' - with old part (before Replace Component).
The main assemblie (whole bed) were made as 'Save As'...
Screens:
http://s29.postimg.org/5lj901v5j/Modeling.png
http://s8.postimg.org/i7dqjpd8l/Specification.png
Thank You in advance
RE: Different solid (look) in "Explosion" and "No Explosion"...
It appears that the cross-bar has moved. Are you using the correct arrangment and/or reference set for the leg assembly?
www.nxjournaling.com
Mr cowski >>> I dont know how... but its true: cross-bar has moved... 'Unexplode Component' is good solution.
Thank You very much
I greet YOU
