how we decide which plane sholuld be primary, secondary & teriary
3
RE: how we decide which plane sholuld be primary, secondary & teriary
When I was trained in GD&T, the instructor said to think about how you would put the piece into a fixture for inspection.
Set the part down on the table, using 3 points of contact. This becomes your primary datum.
Slide the part to 2 points of contact on a side. This becomes the secondary datum.
Push the part to a singlle point of contact to keep it in place. This is your teriary datum.
Simple, effective and constrained.
You want to do as many inspections as you can from a single set of datum callouts as each addittional set requires a new inspection setup and/or fixture.
Ben Loosli
Even better: think about how the part is used. Make datums relevant to most important functional aspects of part. If you do not know what is important to the part, you have bigger problems than getting your drawings finished.
I, too, think you should be divining the part's function not "deciding".
Frank
Quote (fsincox)
So, you want him to guess? Or perhaps you meant defining?
Har har! I've felt at times like I needed a dowser's rod to figure out some people's GD&T, but I guess I'm not the only one, eh Frank? :)
John-Paul Belanger
Geometric Learning Systems
No, basically, you let the nature of how the part actually functions in the assembly lead you to the datum framework! You are only deciding if you are the designer of the assembly!
Frank
I agree, Frank! But I was just riffing off of Cowski, who noticed your choice of words (divining, rather than defining). I just thought it made for a funny joke. (Bad engineering humor, I suppose.)
John-Paul Belanger
I thought it was funny, JP.
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
JP,
FWIW, I also thought it was funny.
To take it a bit further, you could control the straightness of the rod's DML (Divine Median Line) ;^)
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
I agree, I could not think of a better word. I am saying the nature of how it mounts in the assembly leads us to our framework, as the designer we do need to use this to design solid assembly conditions, but I got the strong impression this is just someone looking at a part after it is designed, saying how should I put datums on the part. The old way was to let processing determine datums.
Frank
