where should we use form tolerances
where should we use form tolerances means if i want to give some tolerance on the part drawing where should i give form tolerance ( flatness, straightness, circularity & cylendricity)
RE: where should we use form tolerances
Also not sure it makes much difference but to what GD&T standard are you working?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
http://www.gd-t.com/map-of-gdt/
I'm not a vegetarian because I dislike meat... I'm a vegetarian because I HATE plants!!
John-Paul Belanger
Geometric Learning Systems
