how much methanol in air at a given temperature
Well, I may have a ChemE degree, but I can't for the life of me remember most of the gas phase equillibrium details that I probably once was tested on. I am working with a process that will consist essentially of a stream of air saturated with methanol and water vapor that will be routed to a condensor at 44°F. This will condense out a lot of the water/methanol. Could someone point me in the right direction to get a rough idea of how much methanol will be in the headspace after passing thorugh the condensor? The idea is that there will be a constant flow of the vapor stream and I need to estimate how much methanol vapor is escaping.
-Ryan Birkenholz, Licensed PE in MN and IA
RE: how much methanol in air at a given temperature
The partial pressure of methanol in the air will be equal to the vapor-pressure of methanol at the condensing temperature. This assumes that you get all the vapor down to this temperature.
http://www.erowid.org/archive/rhodium/pdf/methanol...
Ah yes, partial pressures coming back to me now. Thanks for the step in the right direction. This should get me in the right ballpark as all I need is a best guess. I will calculate total moles of gas at condensing temp and 1 atm, then use the ratio of methanol vapor pressure/1 atm to determine methanol cocentration, then use that to get moles of methanol, then convert to mass of methanol using MW. I think that is how it is done. I don't work with this stuff much at work these days. Thanks!
Since the air stream contains more than one condensable component, the partial pressure of methanol in the air will be equal to the vapor-pressure of methanol at the condensing temperature times the mole fraction of methanol in the liquid phase.
You may want to brush up on Raoult's Law, multicomponent gas-liquid systems, dew-point temperature, and dew-point pressure.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
