Hole Callout doesn't translate out to DXF or DWG: NX9
You get the leader but no text. I can live with it but if any one has the answer in their pocket please share! Except for this issue the translator is about perfect.
Very annoying...
TIA for any help
Dave
RE: Hole Callout doesn't translate out to DXF or DWG: NX9
Are we talking about the old hole callouts created using the 'Feature Parameters' function or the new (NX 9.0) hole callouts using the Radial Dimension function?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The new radial one... the old one worked descent in 8.5.
Please contact GTAC immediately and have them open a PR.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John, will do.
Have you tried doing a 'round-trip' test, going from NX -> DXF (or DWG) -> NX?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, I've just verified that this problem only occurs in NX 9.0.0.19. When I tested this in NX 9.0.1.3, doing a 'round-trip' NX -> DXF (and DWG) -> NX, the Hole Callouts came through just fine. You can still go ahead and contact GTAC if you wish as there might be an MP that has been issued to address this.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'll just run the update. Already downloaded from the GTAC site.
Thanks John
