Opening Catia V5R19 drawing file in Catia V5R18
3
Is it possible to open a Catia V5R19 drawing file using Catia V5R18?
MZ7DYJ
RE: Opening Catia V5R19 drawing file in Catia V5R18
only as a step, iges... file, losing the model tree.
you can rebuild that tree, but it's usually pointless or better to model it from scratch.
If you have multiple R19 files, you can use Batch management to Downgrade files to lower releases. However the end result is the same as what loki3000 wrote.
