Step conversion 214
Step conversion 214
Hi all,
Please help me out its urgent.
I have assembly file with a lot sub parts say some 100's, i have to convert that assembly file to stp 214. When i am exporting that to stp 214 it is not opening all the parts as we have in original assembly file. It may missing some parts or it may have some extra part files. Please gimme options so that it can create stp file properly.
RE: Step conversion 214
That is not working.
Vishnu
Using UGNX 7.5
It will all be exported to STEP as a single file, not individual component files that are brought into the assembly, so that is something that you need to consider.
If we use export parasolid the parts with their respective file names remain as same or it will take as with name 'body'
Thanks & Regards,
Vishnu
This is the only way to keep the tree of the assembly.
To filter what you have to export, you have to use the option of the layer
an the object option.
In added you coud suppres the component that you don't need to export.
