ProE WF4 Dimension shows up in the pdf but not in the drawing
Hi - new here.
I am working on a drawing in WF4. When I created a .pdf I noticed that a reference dimension showed up that is obviously incorrect. I went back to the drawing to remove it but it wasn't there. I tried right-clicking over the area and there appears to be nothing at all in that area. I tried the "Show and Erase" function to see if it existed anywhere and it doesn't appear there either. This dimension wasn't in the previous revision of this drawing so I am confused as to how to keep it from showing up in the .pdf short of deleting the view and starting over (which I really would like to avoid).
Any suggestions would be appreciated.
Thanks!
~mpenney
Thanks!
~mpenney
