Can 4 inch Electric deep well pump with oil motor pumping oil in oil industry?
Hello
Can anyone tell me that if it is ok for 4 inch Electric deep well pump with oil motor single phase 220/50hz pumping oil in oil industry?
Any information and suggestion will be appreciated
Thank you.
Thank you.
RE: Can 4 inch Electric deep well pump with oil motor pumping oil in oil industry?
your question is quite vague and short of details which affects the answers you will receive.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
As btrueblood alluded to; you sound like you are talking about throwing an everyday water well pump downhole to use for pumping oil. Of course with no info.....we have to assume. Certainly you would never try that???? Think 300' deep as opposed to over many thousand feet deep.
Think temperature, solids, reliability....and how in the world would you make it up to the production tubing?? Do you really think it would survive the trip downhole? Nope.
I tried to look for Reda pump and found this page,http://www.slb.com/services/production/artificial_..., which shows good video information about oil pumping type pump, it is quiet different than what I thought, every interesting, thank you for your suggestion and information.
This is why 3phs 1,00-4,000V motors are used, to get to the lowest currents possible.
These units also run hot, often 450F internal temp.
In some cases the lift requirements may be up to 14,000', with over 750hp installed.
A far cry from water well pumps.
Plymouth Tube
