An error - too many attempts made for this increment
As I mentioned before, I have a quarter model in Aaqus 6.12 which stands for an entire model of a rectangular plate with a centered hole. I used the orthotropic anisotropic material and defined those 11 constants (c, D, b1111, b2222, b.......). When I did biaxial stretching, I got an error which said
"Too many attempts made for this increment."
I have tried
- to increase the number of iterations per step,
- to adjust loads,
- to change the element size,
- to add automatic stabilization,
but they do not work at all.
I appreciate your help in advance.
RE: An error - too many attempts made for this increment
did you try *analysis = discontinuous it might help
