field coating repair for ARO coated pipe for HDD bore section on pipeline
Hi all,
I understand that 2 part epoxy is common for FBE open cut pipe materials, for bore section where it has to be pulled and coated with ARO for abrasion, what are some options for a good coating for that situation. I'm thinking something in the power crete line but have not experience in that..
thanks for your help.
As much as possible, do it right the first time...
RE: field coating repair for ARO coated pipe for HDD bore section on pipeline
I work at the moment with Resimac products I work and sell it as distributor. In the past I have worked for Belzona. the company Resimac is comming from people which have worked for Belzona and Thortex. Thortex is taken over by 3 M and the |Skotchkote is something from them. At the moment for these applications your either choose for a normal ceramic coating which you can use up to 60 C full immersion. Or a coating the hta or hts depending on the chemical load up to 120 C.
Whenever you would like to have more info. Don't hesitate to contact me.
