Dimension Line value disply
3
I'd like to have the value of both horizontal and vertical dimensions in the middle of the dimension line (the way they are shown in the attachment)m but with one adjustment:
I want the dimension line interrupted on the area where the value is located.
How should I get that?
MZ7DYJ
RE: Dimension Line value disply
Change the drafting standard to ANSI or ASME when you create new drawings.
For exisiting drawings; select all dimensions and change standard or ANSI or ASME
check your drafting standard (XML file)
Eric N.
Thank you both!
MZ7DYJ
If you want to do this in a CATScript...
CODE --> CATScript
Sub CATMain()
   ' Variables declaration
    Dim oDrwDocument As DrawingDocument
    Dim oDrwSheets As DrawingSheets
    Dim oDrwSheet As DrawingSheet
    Dim oDrwView As DrawingView
    Dim oDrwTables As DrawingTables
    Dim oDrwTable As DrawingTable
 Set oDrwDocument = CATIA.ActiveDocument
    ' Set the drawing document standard
CATIA.DisplayFileAlerts = False
	Dim Message, Style, Title, Response, MyString
	Message = ("This macro will change the drawing standard according to what user will choose"  &_
			(chr(13)) &_
			 "	- The active document must be a CATDrawing (local or VPM)"&_
                         (chr(13)) &_
			 "	- Drawing size will go automatically to the biggest standard format"&_
			 (chr(13)) &_
			   ""&(chr(13))&_
"	Do you want to continue ?")
	Style = vbYesNo + vbDefaultButton2    'Define buttons.
	Title = "Purpose "
	Response = MsgBox(Message, Style, Title)
		If Response = vbYes Then    ' User chose Yes.
Dim myStringcase 'As Double
myStringcase = "1"
myStringcase = InputBox ("Please enter the case" & chr(13) & "1 for ISO"  & chr(13) & "2 for ANSI"  & chr(13) & "3 for JIS" , "Standard case" , myStringcase)
If myStringcase = 1 Then
    oDrwDocument.Standard = catISO
ElseIf myStringcase = 2 Then
    oDrwDocument.Standard = catANSI
ElseIf myStringcase = 3 Then
    oDrwDocument.Standard = catJIS
Else
	End If
    '~ Bellow code will work only for ISO standard, if you want to set the size for other standards you need corect name, like catPaperA3
    '~ Uncomment to make it work
    '~ ' Retrieve the drawing document's sheets collection
    '~ Set oDrwSheets = oDrwDocument.Sheets
    '~ ' Retrieve the active sheet
    '~ Set oDrwSheet = oDrwSheets.ActiveSheet
    '~ ' Set the sheet properties
    '~ oDrwSheet.PaperSize = catPaperA3
    '~ oDrwSheet.Orientation = catPaperLandscape
    '~ oDrwSheet.Scale2 = 1
CATIA.ActiveDocument.Update
End If
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
