Deformable part
Deformable part
Making a deformable part with a tube in assembly works fine, but when I try this with a different shape strange things happen.
The shape deforms and the sweep starts at the position where the original has been created and not on the curve in the assembly. Is there anywhere a good tutorial how this works or does this only work with tube.
NX 8.5.1.3
NX 8.5.1.3
RE: Deformable part
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Deformable part
Are you sweeping it along a spline, curves, edges, sketch?
Are you using sweep along a guide, swept or routing?
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: Deformable part
The cable should follow the curves like the tube and this with deformable parts.
RE: Deformable part
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Deformable part
I also had tried 'Sweep along Guide' but my problem was that i forgot to include the coordinate system for the direction of the sketch.
I saw this in your attached file.
Everything works fine now, thank you.
