Converting Curves from Sketch
Hello All,
I created the sketch for some complex shape cutting surface. Now I dont want see the sketch in my navigation tree. i would like to extract the curves from sketch and use it for extrude(cutting surface creation).. Can it be possible?
i m using NX8
Thanks in advance
BGD
RE: Converting Curves from Sketch
Why not use the sketch then make it internal to the extrude feature?
www.nxjournaling.com
Cowski,
I can use sketch for extrude but.... ususally in working with surfacing sketch is not used as i see with GM work which i have been working in plastic Interiors design
Thx
BGD
Some surfacing designs are easier to create/edit without using sketches. However, since you are making a simple extrude feature and already created the sketch - there is no reason NOT to use it.
Insert>Associative Copy>Extract>Composite Curve (Selection intent to Feature Curves, Associative turned OFF)
Although you would be better off just using the sketch to trim, you dont even need to extrude, just trim along a vector.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
Thanks KhimaniMohiki .i understood what i was searching .
Thx
BGD
