UG Updating
UG Updating
Hi All
We are experiencing updating on most of the jobs we open fully. Why is this happening and how can we fix this issue?
James Dufour
James Dufour
RE: UG Updating
Tools>Update>Delay Model Update
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: UG Updating
Ben Loosli
RE: UG Updating
RE: UG Updating
If so, these parts may be updating if the source file is open and marked as modified.
www.nxjournaling.com
RE: UG Updating
Khimani Mohiki
NX8.5
RE: UG Updating
There might be couple of reasons:
(1) Wave linking as already pointed to by cowski
(2) one more reason can be If a part is saved while it's last feature is not the CURRENT FEATURE (i mean if you have used MAKE CURRENT FEATURE on any intermediate feature ) .... Just make the last feature the CURRENT FEATURE and save it back..this should solve the issue.
(3)This might not be truely your case but i have noticed (not in many cases though and at least not in normal modelling) that some how when you work (in a partially loaded state) on an assembly with a complex WAVE LINKING pattern and save it like this...the next time you open it you may find some broken links in some parts and no matter if you fully load it afterwards and save it..the next time you open it ...it will still show parts updating...so the only option avaliable will be to reach out to those broken links and mend them (use relation browser for a quick validation)
Best Regards
Kapil Sharma
RE: UG Updating
RE: UG Updating
As multicaduser and looslib point out the parts may not have saved to the current NX version. This would also occur if the component parts are part family members. Open the part family template and update the members using the latest NX version. Use info, part, loaded parts to check the NX version of the parts.
The NX status line may provide insights in to what and why the updates are occurring. Are there out of date sheet metal flat patterns in any of the parts?
HTH, Joe
