2nd column of part list with autobaloon
Hi ALL
Please look at the picture:
http://postimg.org/image/5557vkzmv/
I have too long partlist and i want to move seven rows to second column... Partlist is related with Autobaloons
thank You in advance
RE: 2nd column of part list with autobaloon
Edit the style of your partslist, and on the "sections" tab ("format" section) change the maximum height (this is a distance expressed in the base length units of your part file) to something that works for you. Also, check the options in the "growth" section of the dialog, particularly the "continuation properties" option.
www.nxjournaling.com
Also make sure your sheet size is big enough to allow your partslist to overflow to the direction you want to go.
