Edge-to-Edge Contact
I've got a 2D model which is a block with a slot and a thin sheet touching on one edge. I've use contact mesh to define CGAP elements along the contact edge and set the gap stifness however when I run the model, the thin sheet passes straight through the block. I've used ADVNL 601,106.
Is there a flag to switch on contact that I've missed?
