Profile and use of "INDIVIDUALLY"
Hi guys,
Is there a difference in interpretation between the two scenarios?
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: Profile and use of "INDIVIDUALLY"
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
You have two separate requirements, as if you applied two FCFs "not touching" each other.
FRTZ only exists if you have compound FCF.
No difference.
I agree with CH that the special rules that go along with FRTZF's only apply in the context of composite FCF's. John's example has multiple single-segment FCF's.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Is there a possibility this can mean something other than what it says without the word 'individually' being used?
I have six holes that when related to A and B, must be within a profile of .5 (like a positional tolerance). And each hole individually must be within a roundness of .1. Right?
My other question is - Is there a SIMULTANEOUS requirement for the .5 profile wrt A and B? Is that assumed because it refers to all six holes? I do not believe there is unless that is specified.
I would like to learn something now.
