24Vdc /10Amp Transformer
Hi, I am currently undertaking a project and I need a 24Vdc/10 amp (minimum) AC to DC power transformer, And I just cant find one, I am based in UK so a UK company would be prefferable. If anyone could point out a store or even a alternate soloution I would be most gratefull.
Thanks......
RE: 24Vdc /10Amp Transformer
If you need a unit providing DC its not called transformer, but many companies manufacturing transformers also supply such power supplies like the one you need.
You need to specify your requirements more exactly:
Whats your input voltage: Single phase or three phase ?
Do you need smooth DC or not ?
Do you need a regulated supply or not ?
Power supplies of that voltage and current rating are widely used for powering PLCs and asscociated loads:
There are three different basic designs avialable:
line-frequency transformer -- rectifier: only suitable for some kinds of loads
line-frequency transformer--rectifier--smoothing: smooth DC but with fluctuating output voltage because of line and load variations
Switchmode Power Supply: smooth and regulated DC
Suggestion: Visit
http://www.thomasregister.com
and enter Power Supplies: AC to DC which will return 202 companies to inquire about your specific needs that are not posted in your original posting.
