Unsure, which material properties I should assign
I am new in Abaqus and my Boss gave me a long plastic Pin, which i should implement in Abaqus.
The properties he gave me are:
Density: 1,26 e -09 t/mm^3
tensile strength: 7,2 N/mm^2
compressive strength: 66,7 N/mm^2
Youngth's modulus for traction: 6200 N/mm^2
diameter: 16 mm
length: 300 mm
I thought about using wires in the part module and beams as the section in the property module. Do you agree?
To implement the density is of course not a problem, but I'm unsure, how to implement traction. Do you have any idea?
Thank you so much for your help!
Launi
diameter: 16 mm
length: 300 mm
Launi
