Finite Difference Method - 1D Conduction
Heat conduction on a insulated rod with the ends at constant temperatures of T0=100 and T10=500 degC. L=0.5m delX=0.05
Governing Equation: d/dx(k dT/dx)=0
Analytical Solution: T=800x + 100
k(d2T/dx2)=0
Central Difference:
d2T/x2=((T,i-1)-2(T,i)+(T,i+1))/delX^2
So for i=1 on k(d2T/dx2)=0
(k/delX^2)(T0-2T1+T2)=0 ???
That means if I set up the matrices
(k/delX^2) [-2 1...] [T1;T2...] = [T0 0...T10]
However I don't get the correct answer. If I drop the (k/delX^2), I get the correct the answer. Why is that?
k(d2T/dx2)=0
Central Difference:
RE: Finite Difference Method - 1D Conduction
