Issue with drafting views attributes being grayed and all solid
I have an issue with my drafting views. The lines are all gray and solid if I plot they are correct. If I change there attributes the color line type etc there is no change in views. this is a global issue. I'm running V5 R19 I tried to reload software but problem is till there.
RE: Issue with drafting views attributes being grayed and all solid
Before anything else, I would try to delete CATSettings files.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
You can just turn this option off (Filter Generated element) :
My IT guy is reformatting my workstation I will need to reload Catia try this,
I will get back when he is completed.
That was the problem visual filter was on. I do not use the from much but I read it and learn a lot.
I appreciate this resource and all you guys involved.
Question when or how is this function used not start an other thread or should I?
Franklin
